Hardenability of Steels
Steel name: Steel
Diagram No.: 1946
AS designation: No data
Chemical composition in weight %: No data
Steel group: Steels
Comment: Specification of hardenability limits: The hardenability of the steel shall be specified in terms of the tabulated hardness limits for the following distances from the quenched end of the test specimen: 1.5, 3, 5, 9, 13, 20, 25 and 30 mm.
Notes:
1 No result below 20 HRC need be reported. See AS 1815.1 for the method of conducting the Rockwell hardness test.
2 For convenience in the estimating of hardness values at various locations on the end-quench test bar and for quick comparison of the various grades, hardenability values are also plotted on graphs which are for guidance only.
3 The curves for individual heats may vary in shape from the standard band, and thus may deviate slightly at one or more positions along the full length of the band. A tolerance of two points HRC is therefore permissible over any small portion of the curve, except at the 1.5 mm position.
4 Alternatively, two points may be used to specify hardenability, in several ways, as follows:
(a) The minimum and maximum distances at which any derived hardness value occurs (points A-A' in Figure 1).
(b) The minimum and maximum hardness at any given distance (points B-B' in Figure 1).
(c) Maximum hardness values at two desired distances (points C-C' in Figure 1).
(d) Minimum hardness values at two desired distances (points D-D' in Figure 1).
(e) Any minimum hardness plus any maximum hardness.
Where hardenability is specified by one of the ways given in items (a) to (e), the maximum and minimum hardness values at 1.5 mm may also be specified in addition to the other two points.
Figure 1: Examples of the use of two points to specify hardenability limits.
