NITRALLOY 135 Steel
Steel name: NITRALLOY 135
Diagram No.: 1990
AMS designation: AMS 6470 (Air Melt)-299-947-036 (Bell Helicopter), AMS 6471-299-947-083 (VIM-VAR) (Bell Helicopter), AMS-S-6709 (Air Melt)-B50TA314 (General Electric)
Chemical composition in weight %: 0.40% C, 0.30% Si, 0.60% Mn, 1.60% Cr, 0.35% Mo, 1.20% Al
Steel group: Nitriding steels
Applications: Aircraft gears, shafts, pinions, crankshafts, cams, camshafts and bolts.
Comment: NITRALLOY 135 MODIFIED VAC-ARC steel is a low alloy nitriding grade with moderate hardenability. It has been designed to provide a high case hardness and to maintain its core strength during the nitriding cycle. VAC-ARC remelting is employed to provide preferred ingot solidification and superior microcleanliness. Nitralloy 135 Modified Vac-Arc steel is also produced by vacuum induction melting followed by vacuum arc remelting (VIM-VAR).
Hardening: Heat to 1700-1750°F (927-954°C) for ½ hour per inch of cross section and quench into oil or water. Water quenching is preferred when the cross section exceeds 1 inch in thickness.
Tempering: Heat to 1000-1300°F (538-704°C) depending on the desired hardness. Material should be tempered for 1 hour per inch of thickness.
