66SiMnCrMo6-6-4 Steel
Steel name: 66SiMnCrMo6-6-4
Diagram No.: 2036
DIN designation: 66SiMnCrMo6-6-4
Chemical composition in weight %: See the table.
Steel group: Bearing steels
Comment: Ovako 677L & 677Q is an air-hardening bearing steel with high mechanical strength and fatigue properties. By using gas cooling or air-hardening it is possible to reduce the amount of distortion. Additionally the use of quenching medias such as oil and salt can be avoided, which improves both safety and environment. Similar designation: 66SiMnCrMo6-6-4. Ac1=768 C, Ac3=792 C, Ms=193.
Hardening: 880-1000°C, directly hardened in air or by gas quenching.
