Cm60 Steel
Steel name: Cm60
Diagram No.: 467
DIN designation: Cm60
Mat.No. (Wr.Nr.) designation: 1.1223
Chemical composition in weight %: 0.57-0.65% C, max. 0.40% Si, 0.60-0.90% Mn, max. 0.030% P, 0.020-0.040% S, max. 0.40% Cr, max. 0.10% Mo, max. 0.40% Ni
Steel group: Non alloy special steels
Comment: No data
Hardening in water: 810-850oC
Hardening in oil: 810-850oC
Tempering: 550-660oC
End quench test: 825-835oC
Disclaimer: The information and data presented herein are typical or average values and are not a guarantee of maximum or minimum values. Applications specifically suggested for material described herein are made solely for the purpose of illustration to enable the reader to make his own evaluation and are not intended as warranties, either express or implied, of fitness for these or other purposes. There is no representation that the recipient of this literature will receive updated editions as the become available.
