SNCM220 Steel
Steel name: SNCM220
Diagram No.: 1453
AISI/SAE designation: 8620
JIS designation: SNCM220
Chemical composition in weight %: 0.17-0.23% C, 0.15-0.35% Si, 0.60-0.90% Mn, max. 0.030% P, max. 0.030% S, 0.40-0.70% Ni, 0.40-0.65% Cr, 0.15-0.30% Mo, max. 0.30% Cu
Steel group: Case hardening steel
Applications: Gear,shaft, screw,winch, nut, bobbin, shaped roll.
Comment: No data
Hardening: 1.) Heat to 850~900C, oil cooling. 2.) Heat to 800~850C, oil cooling.
Tempering: Heat to approx. 150~200C, air cooling.
