18CrNiMo7-6 Steel
Steel name: 18CrNiMo7-6
Diagram No.: 1454
DIN designation: 18CrNiMo7-6
Mat.No. (Wr.Nr.) designation: 1.6587
Chemical composition in weight %: 0.15-0.21% C, 1.50-1.80% Cr, 0.25-0.35% Mo, 1.40-1.70% Ni
Applications: Gears
Comment: Figure shows the effect of compositional modifications on the hardenability of a 0.18% C reference carburizing steel (18CrNiMo7-6). The powerful effect of adding carbide formers is apparent. In this figure, the solid line shows the hardenability of the reference steel. Raising the Ni content and lowering Mo (bottom dashed line) raises core toughness by promoting bainite formation, but decreases case hardness by increasing the fraction of retained austenite after carburization. Alloying with a combination of Mo and special carbide formers (top dashed line) raises the hardness of the component uniformly, and increases the case hardness above the basic hardness of 0f 0.18% C steel (dotted line).
Jominy test results on two modified 18CrNiMo7-6 (solid line) steels, showing how Mo additions can improve the performance of windmill gearboxes.
