12NiCr14-6 Steel
Steel name: 12NiCr14-6
Diagram No.: 1512
DIN designation: 12NiCr14-6
Chemical composition in weight %: 0.10-0.15% C, 0.15-0.35% Si, 0.40-0.60% Mn, max. 0.020% P, max. 0.010% S, 1.35-1.60% Cr, 3.25-3.75% Ni, max. 0.15% Mo
Applications: (Bearing Quality) is a bearing quality clean steel optimized for fatigue strength by a strict control of steel cleanliness. BQ-steel is also ideal for new design solutions in a wide array of demanding applications outside the bearing industry that require longer performance and higher loads.
Comment: Ovako 245 is an ingot cast case hardening steel with high toughness of the type SAE 3311. It fulfills Ovako internal BQ-Steel demands ensuring a high microscopic and macroscopic cleanliness. Ms=395 C, Ac1=694 C, Ac3=806 C.
Hardening: 840-890oC/oil
Carburizing: 850-930oC
