20MnCr5 Steel
Steel name: 20MnCr5
Diagram No.: 1520
DIN designation: 20MnCr5
Chemical composition in weight %: 0.17-0.22% C, 0.10-0.25% Si, 1.10-1.30% Mn, max. 0.025% P, max. 0.002% S, 1.00-1.20% Cr, 0.10-0.25% Ni, max. 0.08% Mo, 0.050-0.200% Al
Applications: Case-hardening steel with low carbon content but good hardenability reaching good wear resistance due to high surface hardness after hardening. The small grain size benefits in good ductility and fatigue strength. Suitable for gearboxes and axle gears.
Comment: Similar designations: 20MnCrS5, 1.7147, 20MnCr4. Ms=385 C, Ac1=731 C, Ac3=831 C.
Hardening: 830 - 870oC/Quenching in oil or water
Tempering: 150 - 200oC/air
