27MnCrB5-2 Steel
Steel name: 27MnCrB5-2
Diagram No.: 1529
DIN designation: 27MnCrB5-2
Chemical composition in weight %: 0.25-0.30% C, 0.15-0.35% Si, 1.00-1.40% Mn, max. 0.035% P, max. 0.035% S, 0.30-0.60% Cr, max. 0.040% Al, 0.0010-0.0060% B
Steel group: Alloy steels, boron steels
Applications: (Wear resistant ) WR-steel, stands for wear-resistant steel. This group of steel includes a broad range of grades with a wide range of hardness levels 350 – 650 HV, dimensions and steel grades designed to give you a wear-resistant advantage when making product exposed to a high degree of wear and where service life is important.
Comment: Ms=382 C, Ac1=720 C, Ac3=786 C.
Hardening: 880-910oC/in water or oil
