28MnB5 Steel
Steel name: 28MnB5
Diagram No.: 1530
DIN designation: 28MnB5
Chemical composition in weight %: 0.25-0.30% C, 0.15-0.35% Si, 1.10-1.30% Mn, max. 0.025% P, max. 0.015% S, 0.15-0.25% Cr, 0.010-0.040% Al, 0.0010-0.0050% B
Steel group: Alloy steels, boron steels
Applications: Grade SB27M12Bm is boron steel used in quenched and tempered condition. The material is suitable for moderately or highly stressed parts such as wear parts on agricultural, forestry and excavators. The grade has tighter chemical analysis than grade SB27M12CB and is recommended for thickness .15 mm. Its closest equivalent is 28MnB5 (1.0871).
Comment: Ms=379 C, Ac1=720 C, Ac3=784 C.
