29MnCrB5-2 Steel
Steel name: 29MnCrB5-2
Diagram No.: 1531
DIN designation: 29MnCrB5-2
Chemical composition in weight %: 0.28-0.33% C, 0.15-0.40% Si, 1.10-1.50% Mn, max. 0.030% P, max. 0.030% S, 0.25-0.60% Cr, 0.0020-0.0050% B
Steel group: Alloy steels, boron steels
Applications: (Wear resistant ) WR-steel, stands for wear-resistant steel. This group of steel includes a broad range of grades with a wide range of hardness levels 350 – 650 HV, dimensions and steel grades designed to give you a wear-resistant advantage when making product exposed to a high degree of wear and where service life is important. WR-steels are characterised by consistent properties and cost effectiveness due to optimized alloy content for different end applications.
Comment: Ms=368 C, Ac1=720 C, Ac3=781 C. Boron grade 29MnCrB5-2 is a non-standardised grade located in between 27MnCrB5-2 and 33MnCrB5-2. It is suitable for wear parts, but may be heat-treated for good toughness if needed. A tight chemical composition ensures repeatable heat-treatment response.
Hardening: 880-900oC/in water, oil
