39MnCrB6-2 Steel
Steel name: 39MnCrB6-2
Diagram No.: 1535
DIN designation: 39MnCrB6-2
Mat.No. (Wr.Nr.) designation: 1.7189
Chemical composition in weight %: 0.36-0.42% C, 0.15-0.35% Si, 1.30-1.70% Mn, max. 0.035% P, max. 0.035% S, 0.30-0.60% Cr, 0.0008-0.0050% B
Steel group: Alloy steels, boron steels
Applications: This grade is classified as a WR-steel, which stands for wear-resistant steel. This group of steel includes a broad range of grades with a wide range of hardness levels 350 – 650 HV, dimensions and steel grades designed to give you a wear-resistant advantage when making product exposed to a high degree of wear and where service life is important. WR-steels are characterised by consistent properties and cost effectiveness due to optimized alloy content for different end applications.
Comment: Ms=350, Ac1=720 C, Ac3=805 C.
Hardening: 840-870oC/in oil
Tempering: 180-230oC/1 h
