20MoCrS4 Steel
Steel name: 20MoCrS4
Diagram No.: 2029
DIN designation: 20MoCrS4
Chemical composition in weight %: 0.18-0.22% C, 0.15-0.35% Si, 0.70-0.90% Mn, max. 0.035% P, 0.020-0.035% S, 0.40-0.50% Cr, 0.40-0.50% Mo, max. 0.20% Ni max. 0.10% V
Steel group: Alloyed steels
Applications: Ovako 124D is a Chrome-Molybdenum alloyed steel used mainly as a carburizing grade, but may also be used in Q&T condition of its own from the 0.2% Carbon level. By also being alloyed with Sulphur the machinability is improved in low speed cutting as eg Broaching. This makes Ovako 124D very suitable for gears, but also other components with heavy machining by drilling or milling like Gear wheels in Hydraulic pumps. From being Ingot cast the cleanliness is following the base cleanliness from the Ovako Ingot process rouite.
Comment: Similar designations: 20MoCr4. Ac1=735 C, Ac3=860 C, Ms=440 C. Jominy temperature: 900°C for Ovako 124D. 910°C for 20MoCrS4 EN 10084:2008.
Hardening: No data
