20NiCrMo7 Steel
Steel name: 20NiCrMo7
Diagram No.: 2030
DIN designation: 20NiCrMo7
ASTM designation: ASTM 4320, ASTM 4320H, ASTM 4320RH
Chemical composition in weight %: 0.17-0.22% C, 0.20-0.30% Si, 0.55-0.65% Mn, max. 0.015% P, 0.002-0.005% S, 0.50-0.60% Cr, 0.23-0.28% Mo, 1.65-2.00% Ni max. 0.014% V
Applications: Ovako 157 is a high cleanliness case hardening steel used for bearing and transmission components. There are three different modifications of the grade. BQ-steel is a bearing quality clean steel optimized for fatigue strength and is also ideal for new design solutions outside the bearing industry.
Comment: Ac1=704 C, Ac3=806 C, Ms=400 C.
Hardening: 840-890 C, oil.
Disclaimer: The material data is a central depository of information based on global actual tests and calculated software data that is available to the public for a fee. The information and data presented herein are typical or average values and are not a guarantee of maximum or minimum values. Applications specifically suggested for material described herein are made solely for the purpose of illustration to enable the reader to make his own evaluation and are not intended as warranties, either express or implied, of fitness for these or other purposes. There is no representation that the recipient of this literature will receive updated editions as the become available. 0302030
