42CrMo4 Steel
Steel name: 42CrMo4
Diagram No.: 2034
DIN designation: 42CrMo4
Chemical composition in weight %: See the table.
Steel group: Alloyed steels
Comment: 42CrMo4 is a steel for quenching and tempering, which has a good combination of strength and toughness in the quenched and tempered condition. After the oil quenching, the steel will be through hardened up to ø60 mm bar diameter. The microstructure of larger dimensions is not fully martensite. The steel is applicable to induction hardening. The surface hardness will exceed min. 53 HRC. 42CrMo4 can be delivered M-treated in order to optimize the machinability.
Hardening: 840-880°C, in oil or water. Temper in 540-680°C.
