Hybrid 55 Steel
Steel name: Hybrid 55
Diagram No.: 2043
Chemical composition in weight %: 0.20% C, 0.10% Si, 0.30% Mn, 3 ppm S, 5.10% Cr, 0.70% Mo, 6.10% Ni, 0.50% V, 2.4 ppm Al, 3 ppm O, 28 ppm N
Steel group: High strenth steels
Applications: Forming tools, sharp edge applications, engine components, nitrided components, fuel injection components, bearings
Comment: Jominy curve of Hybrid 55 shows a very high hardenability, allowing slow cooling after heat treatment, resulting in low distortion. Hybrid Steel has up to three times the yield and tensile strength of conventional steel at temperatures up to 500°C. With properties normally found in other specialty steels, it bridges performance gaps to create a whole new steel category.
Hardening: No data
