0.18C-0.17Si-0.76Mn-0.54Cr-0.75Mo-1.76Ni Steel
Steel name: 0.18C-0.17Si-0.76Mn-0.54Cr-0.75Mo-1.76Ni
Diagram No.: 2054
Chemical composition in weight %: 0.18% C, 0.17% Si, 0.76% Mn, 0.54% Cr, 0.75% Mo, 1.76% Ni
Steel group: Alloyed steels
Comment: Standard Jominy end-quench specimens were machined from normalized bar stock. These were austenitized at 927 C (1700 F) and end-quenched in accordance with SAE Standard J406. After quenching, parallel fiats were surface ground to a depth of 0.76 mm (0.03 inch) along the sides of the bar. This depth, in excess of the specified minimum, was necessary to produce a fiat of sufficient width for the hardness tests performed in this study. Jominy curve for a steel of high hardenability.
Hardening: 927 C, water
