16MnCrB5 Steel
Steel name: 16MnCrB5
Diagram No.: 60
DIN designation: 16MnCrB5
Mat.No. (Wr.Nr.) designation: 1.7160
Chemical composition in weight %: 0.14-0.19% C, max. 0.40% Si, 1.00-1.30% Mn, max. 0.025% P,
max. 0.035% S, 0.80-1.10% Cr, 0.0008-0.0050% B
Steel group: Structural and constructional steels, boron steels
Applications: Steel rod, bars and wire for cold heading and cold extrusion. Case hardening steels:
Components subject to wear like gearing, piston pins, camshafts
Comment: No data
Carburising: 880-980oC
Hardening: 870oC
Core hardening: 860-900oC
Surface hardening: 720-820oC
Tempering: 150-200oC
Note: End quench test: 870oC
